Johnny Five is Alive, TCCoAAC Member
The newer VB's are better. I wouldn't use an older style VB in a new 4r
There is a conversion kit to convert the dowl pins to use the older style 4r in a new style 4r trannie.
So the answer is no - there is a dowl pin change? It isn't that I would want to do this kind of swap - but I assume that NEW 4r VB's fit ALL old 4R's correct? The tranny istself is cake.....it is the vb diffrences and control that gets me all confused.
With the sleeves to fo over the dowel pins on the VB, a 99+ (or best an 01+ VB) can be retrofitted to any AODE/4R70W. It's more a matter of year than model IIRC. 96+ have a different thickness plate, and there are different EPC brackets - so if you update the VB to a 96+ on a pre96 car, you'll need the correct bracket. From what I gathered from Jerry's article on our site, a 94 AODE VB will interchange with a 94 4R70W VB physically. There may be minor spring difference inside, but there have been dozens of those changes over the years, and none of them should be that drastic. You can't fit a pre96 VB onto a 96+ trans (luckily).
