1 - 1 of 1 Posts
I have an AOD with several good parts that I want to upgrage. I have the mechanical diode and a donor 4r70.... I know I need the reverse drum and am also looking at swapping in the wide ratio. what all else is needed????
Also the AOD that I tore down had the needle/roller bearings in it. Will I be able to use these with the 4r70 swap????
1 - 1 of 1 Posts
