1 - 12 of 12 Posts
According to my Ford dealer, my car needs new front pump gaskets, a pump oring and a filler tube oring. My question: how many front pump gaskets are there to replace? I would ask him, but after he quoted me $870something to fix it I asked him to stop molesting my car and took it back. So how many of those gaskets do I need to order so I can fix it myself? Thanks,
Will
I believe there are 2. I have my new one at home, but can't remember how many there are for sure. If no one knows, I can look when I get home.
Jay
So how many of each do I need, just one? Also, where exactly is the pump in the trans and how hard is it to replace these items?
There are 1 of each. The pump is the first thing behind the torque converter. How hard it is depends on you, I think it's easy. I have replaced pumps on a4ld transmissions so after that a 4r70w is a piece of cake.
Alan
Never done it before, but it sounds like a mighty good time to throw in a Marauder torque converter while I'm at it...
I ask this because the dealer says these are the parts that are leaking. Does that make sense, or is it just more dealer BS? There is a leak from somewhere north of the pan gasket.
I would install a new pump bushing and install a m/d reverse drum with the snap ring welded on if it were mine. Might be a good time to upgrade the intermediate clutches and put in a new OD band.
Alan
you basically will have to pull the drive shaft, and pull the whole trans down, then remove the TC, remove the bolts to the front pump.
Then you need a slide hammer, actually two works better.
Hopefully it is a replacable seal, instead of damage to a metal face.
If I were you I'd put in a mechanical one way diode/reverse drum, heck clutch packs if you have the time.
I'm not familar with the weld on snap ring, but I used a spiroloc - G lock ring to retain the reverse hub, which is far less risk of coming loose at high-rpm compared to the stock snap ring.
Anybody have p/n's for the two gaskets and o-ring? from http://www.bulkpart.com
Not sure if these are correct, they are listed for the AOD-E and the AOD, still missing one gasket.
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=27128&Category_Code=AODg
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=27251&Category_Code=AODg
edit::
Here is the G-Lock ring kit
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=27470&Category_Code=AODhp
Edit::
Mechanical diode
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=27783B-K&Category_Code=AODhp
Here's my trans buildup parts list, all Ford stuff there.
http://www.teeps.com/discreppts.htm
ChadG's rebuild list, some of this is overlapping.
Here's my list for comparison, has everything I needed to upgrade my old '97 except the new reverse drum PN, which I have at home. And be sure to get the spiral retaining ring from Matco to hold the OWC on.
Description Part Number Price
Manual Lever Position Sensor F4SZ-7A256-A $29.18
MLPS Stud E9SZ-7B415-A $5.84
Output Shaft F4SZ-7060-A $197.10
5.4L Planetary Gear XL3Z-7A398-AA $206.31
Forward Sun Gear XL3Z-7A399-AA $46.75
Direct Friction Plate F8AZ-7B164-BA $2.18
Direct Steel Plate F6AZ-7B442-AA $3.17
Direct Snap Ring F3AZ-7D483-A $4.08
Forward Pressure Plate F0SZ-7B066-B $7.10
Forward Friction Plate F8AZ-7B164-AA $2.45
Forward Steel Plate F0SZ-7B442-A $2.04
Forward Snap Ring F0SZ-7D483-D $6.29
Reverse Cylinder Assy F8AZ-7A089-AA $44.01
Intermediate Pressure Plate F7AZ-7B066-AA $9.69
Intermediate Friction Plate F3LY-7B164-A $3.47
Intermediate Steel Plate XL3Z-7B442-BA $4.21
Stub Shaft F8AZ-7F351-AA $8.54
Stator Support F4AZ-7A108-A $109.52
Fwd Cl Seal Rings F4AZ-7D019-A $6.11
Rev Cl Seal Rings E0AZ-7D020-A $3.74
OD Servo Assy F75Z-7H188-AA $21.90
OD Servo Ret Spring F2VY-7F201-A $21.35
OD Band F2TZ-7F196-A $10.28
Press Ctrl Solenoid XL3Z-7G383-AA $46.82
1-2 Accum F7AZ-7F251-AA $10.19
1-2 Accum Cover F4AZ-7F247-A $3.55
2-3 Accum F7AZ-7H292-AA $5.27
Reverse Servo E0AZ-7D189-AVMR $9.96
99 Main Control XW7Z-7A100-CA $231.13
Top Seperator Plate Gasket 1L3Z-7C155-AA $1.31
Bottom Seperator Plate Gasket XW7Z-7D100-AA $1.13
Top Accum Spring F75Z-7F284-BA $2.68
1 - 12 of 12 Posts
