1 - 17 of 17 Posts
Fry Rice Specialist
one quick question, do the valvebody need to be taken out in order to pull the internal?
got the front pump off but when i want to pull out the internal seems like someting is holding it back. suspecting maybe the od servo or something small is holding it back.
thanks.
Fry Rice Specialist
thanks a lot man. this answer my question. is it the first snap ring that are behind the pump that always fail? or something else?
may still bug you guys with some question soon.
Fry Rice Specialist
Fry Rice Specialist
wonderd what is the yellow plastic thing for? kinda like a washer or something...
how about the failure snap ring? is this the one? what are the option to remedy this?
Fry Rice Specialist
which snap ring to weld and how do you weld it? it's got a big gap in the front snap ring? which page in the jerry article? i'm having hard time finding it...
If you want to send me the drum I'll weld it for you, free of charge. It's the reverse drum which has the diode on it. I highly suggest not using a mig to weld it, slag gets in the thing and problems happen.
Alan
Fry Rice Specialist
thanks for your offer. too good of a deal to not accept it. once i take it out it'll be on your way.
thanks.
Fry Rice Specialist
open a can of worms...what am i doing???
:D
in the pic below is it the one on the 12 o'clock position part that need the snap ring weld?
this pic is upside down, but is the band sitting in the correct position?
Fry Rice Specialist
i think the band needs to be rotated one more so that the piston can squeaze it when its pushed in . Why didt you find a service manual or something before you took it all apart?
i did have the factory manual here, but the problem is the drawing doesn't show clearly where the end suppose to sit...
The words that I tell everyone that I have ever trained to do anything come to mind here.
"If you pay attention to how you take it apart then you shoud be able to put it back together the same way."
I don't want to rain on your parade, but the band is in wrong and it should be pretty obvious as to how. Just take a look at it and think about how it operates. Its really very simple. You don't even have the parts in there in the right order.
I am very concerned that if this thing here causes you problems then you are in for a very rough road with this. That has to be about the simplest part next to threading in a bolt that there is on those. Be very careful.
Darrin
Fry Rice Specialist
Discussion Starter #15
kinda figure out yesterday. i believe this is the right order now.
the 1/2" bottom fixed pin kinda wedge on one side of the stopper and the servo rod wedge the other side right?
this thing kinda just snap out when i pulled the drum so that's why i didn't paid enough attention.
thanks.
Well you have the band against its stop and against the pin, but you are not in the right order still. That band is that last thing that goes in before you put the intermediate clutch plate stack in.
You need to get the right stuff in the right places and in the proper order or you will have big problems.
Darrin
Fry Rice Specialist
Discussion Starter #17
Darrin
thanks. the pic is just kinda want to show if the band sit in the right position or not. the tranny is still not ready to being put together yet.
thanks a lot and i appreciate the input.
1 - 17 of 17 Posts
