Hello
does any one make a manual valve body for this transmission? To use without a computer?
I will only be using on the race track, So auto shifting not needed. I only need 1 & 2 + R
PAUL
if you retain the EEC for transmission control and get a chip, it could disable certain EEC parameters and allow you to manually control the shifting schedules .
manual valve body
Hello
My car does not have the ECC. All electrical was removed. I run my car as a stock car. I have to run a 2bbl. carb only! Remove all glass, bolt or chain doors.
I went to the dura spark II ing.
I want the 4r70w wide ratio transmission.
Paul
Fry Rice Specialist
lentech as post above.
