1 - 11 of 11 Posts
hey all my question is, what needs to be changed when putting a 99 or 00 mustang 4R70W in a t-bird? and 99+ are the good ones correct? and would be safe to j-mod the piss out of rite?
thanks
Marc
Discussion Starter #2
anybody have a picture of where the MLPS and TCC are located on my stock transmission?
i got what i need i think, i repin the connector, and pull my TCC and MLPS and put them on the 99+ trans.
if im wrong please correct me with the information i need
Marc
you dont j-mod the piss out of it....you drill a few holes. you will have to verify the if it has a geared VSS or magnetic pickup or not.
Chapter Director Coordinator
so long as he gets a 99-02 he should be fine
the MLPS is on the side of the transmission, a large cable bolts to it and it has a movable lever
the left side or right side? the trans is a 2000 gt trans, so here is the question, how do i verify if it has the geard vss or magnetic pickup and what is the difference between the two?
pull the VSS harness thingy out of the case...its on the driverside. If it has a plastic gear....its not magnetic....just like when you changed the VSS gear when you put in my 3.27s.
well i never changed the speedo gear but i get what ur saying now....so what do i do if its a magnetic thingamabob?
oh ok, do those correct speedo's for any gear ratio?
yes
1 - 11 of 11 Posts
