1 - 20 of 76 Posts
Ive got a 4r70w with a 3800 stall and an 11 x7 bm cooler mounted up in the front bumper
I was datalogging today with my laptop after having some weird issues with the trans lately ( random 3rd to 4th downshifting, etc.) and noticed it was running 210-220 degrees today.
Im assuming this cant be good.
The weird thing is that the fluid seems to struggle to heat up in the winter
( converter wont lock up for 10 minutes)
I was thinking about adding a second cooler since this seems to be burning up my fluid real fast.
Could it just be the location of my cooler is bad or maybe the coolant is heating up the fluid, coolant was running about 210 also.
Any thoughts?
I can try, its dark out now.
Here is a picture showing you where its at. Ill explain how its setup.
Its mounted right in the front but mostly hidden up in a little cubby of the front bumper.
The metal line running from the factory cooler is cut in half and the cooler is wired in between.
I can get better pictures tomorrow but the lines are fine, not kinked or anything.
Ok I'll cut to the point, limit the rubber to 8 inches in the longest run, change it to 3/8 lines and run the cooler in series before the radiator. If that doesn't do it the transmission is slipping.
Alan
Alan
Im using the 3/8 rubber lines that came with the kit and I dont think the runs are longer than 8 inches.
Can you explain what you mean by running the cooler in series?
Isnt there only one way to run it?
And I was datalogging slip across converter, nothing abnormal and keep in mind this is a rebuilt, upgraded pretty much everything 4r70w within 30k miles.
The car just went [email protected] 121 with 384 rwhp...I dont think its slipping.
Get a real cooler that's built for babies get the 45,000 btu true cool that's what I run temps with 100 degrees don't go above 150-160
Anyone have any idea if this could cause the transmission to do funny things?
It makes sense because it would only do it during the hottest part of the day, I took it out later in the night and the temps would barely go 190-200 and I couldnt get it to do anything weird.
It would go 4-3-4-3-4-3 for no reason...usually when I got on it and got the fluid a bit hotter I guess
There is no way the rubber is less than 8 inches unless you made some steel up. I'll be posting some pics of a setup tonight, I'll try to remember to put a link here when I do. Yes coolers can be run many different ways.
Stand alone= without the radiator
Before the radiator or after the radiator.
After the radiator is best for max cooling on a small cooler. Before the radiator with a medium cooler is great for cold weather environments as it keeps the fluid the right temp or stand alone with a large cooler works quite well for hot combinations that do not see winter driving or you can block off the airflow for the winter with a piece of cardboard.
Alan
Alan
The rubber connects to a metal tube that carries the fluid from the radiator to the transmission.
The cooler is connected in the middle of it and the rubber connects to the metal tubing...it is probably around 8 inches of tubing.
Either way, I feel as if the cooler is too small. The oil temp never really goes down..it remains stable when im cruising but it seems like the cooler isnt actually cooling and the temp flys up as soon as the converter is unlocked or I get on it.
220 degree's is a bit on the high side. I usually try to keep a trans between 180-190, anything over 200 is eventually going to cause trans damage.
What's the fluid look like as in the color/smell?
Also are you SURE it's going in and out of overdrive (4th), and NOT just the converter locking/unlocking? A stock 4R70W will lock up in 3rd when the speed is great enough (over 35mph, I think) and continue locked as it shifts into OD. My trans will lockup as soon as I go over 40mph doesn't matter if it's dead cold or up to running temp.
If you have a stacked-plate type cooler, it will warm faster in cooler weather than the tube and fin type will.
With the high stall converter, ditch the radiator tank cooler and run the BIG cooler as a stand alone transmission cooler. BOTH the tranny and engine temps will be lower. Do it now and put in fresh tranny fluid for the longevity of the transmission before it's too late. As a rule of thumb, for every 20* over 175*, the fluid life is halved.
At 195 degrees F., for instance, fluid life is reduced to 50,000 miles. At 220 degrees, which is commonly encountered in many transmissions, the fluid is only good for about 25,000 miles. At 240 degrees F., the fluid won't go much over 10,000 miles. Add another 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or 300 degrees F., and 1,000 to 1,500 miles is about all you'll get before the transmission burns up
If cold weather becomes a problem, you can run a thermostatic valve with the cooler which basically bypasses the cooler until the fluid warms up where it will start to open flow to the cooler.
Discussion Starter #16
Yea, thats why I was worried and ordered a better cooler.
The fluid is pretty new, probably 10k miles on it however it definately had signs of being too hot...slight burn smell and slight discoloration.
I flushed 5 new quarts into it today.
and im 100% sure it was going 4th to 3rd and not just unlocking.
The problem seems to only happen when the fluid is hot cause I cant get it to do it at all when its night time and cooler out.
Hopefully I didnt hurt anything...gonna try and take it easy untill I can get the bigger cooler and see if that helps.
Unless you bent new steel lines for it I don't see how it is possible to only have 8 inches of rubber with the cooler in front of the radiator. If you bent the stock lines out to meet the rubber hose that is probably your problem even if you do not see it from the outside. with a high stall converter you cannot go wrong going 3/8 tubing.
Some things to keep in mind.
Cooler type. Straight through coolers do not hold the fluid long enough to cool it (not your problem)
Restricted flow from a bent line or a rubber hose with too sharp of a bend, can quickly overheat a transmission and explain slow to warm in the winter. the fluid moves too slow.
Airflow, I like to have the cooler at least 1/2 from the radiator, the farther the better as long as you aren't talking about more than a foot where airflow would be a problem. Make sure the cooler is in a place the fan will draw air through it.
Rubber hose insulates the fluid, metal tube dissipates heat.
Fluid type, make sure you use the right stuff. More expensive isn't always better, pay attention to the ratings on it.
Hope that helps.
Alan
Discussion Starter #18
Hmm, the cold weather would be a problem cause I drive my car all year round and already have a bit of trouble getting the fluid hot enough in the winter.
I drained the pan and swapped 5 qts of fresh fluid into the trans today.
Is it really that beneficial to run the trans cooler as a stand alone?
Im honestly not even sure how I would do that
Discussion Starter #19
Hope that helps.
Alan
Thanks, I will check the tubing again and make sure its not bent anywhere, I have drained fluid from those lines and it comes out of there in a hurry though.
My trans fluid in winter only makes 95-100 degrees lol but I don't drive the car enough to matter
1 - 20 of 76 Posts
