· Fry Rice Specialist
can the pump from 4r75w be use on the 4r70w?
if yes what is the advantage?
Discussion Starter · #2 ·
anyone have any input?
thanks.
Discussion Starter · #4 ·
what piston setup do i need other than the 4r75w pump?
is it just the piston setup and the pump that's it or something else?
what so better is the pump 4r75w over the 4r70w unit? durability? stoutness? higher fluid pump pressure?
thanks.
· Registered
Its a better setup. Its just different and kind of hard to explain unless you know what it looks like. Instead of haivng 9 little springs attached to a retainer that clips onto the pump it has a molded piston and a wave plate. You would need all the parts for the intermediate setup and I don't know what the pump comes with for sure yet.
Darrin
