1 - 2 of 2 Posts
ok gang i have a 347 stroker fairly mild that i had in a 93 bird but got sideswiped car totaled so picked up a 96 cougar what would b the best way to do this swap? ie crank trigger or go with distrubeter and control box or what? also anyone no of headers that will work in this application thank u
If you’re a junkyard rat like me you could convert it to DIS using 96-01 explorer cam sensor that goes in place of the distributer and use DIS coil packs, and simply modify the Cougar’s 4.6 engine harness to fit the 5.0. Then just get a tune for the existing computer to run it
There are Mustang headers that can be made to fit but I’m a 4.6 guy and can’t remember specifics, check through the 5.0 section, the info is definitely there.
1 - 2 of 2 Posts
