$450 obo. I can deliver within 100 miles of Southington, Ct for $.50 a mile (pay for one way that's it)
89-93 style M5R2 w/63k miles new fluid and fresh paint (silver)
Crossmember with new bushings and mounts
Slave cylinder, resovoir, clutch master, and hyd. line with only 10 miles on it
Clutch and brake pedals
Driveshaft
Wiring
Flywheel (resurfaced w/10 miles)
Used LUK clutch w/ around 20k on it (lots of meat no slipping)
Shifter plate
Center console w/shift boot (grey or black)
ECM
Every nut and bolt
All you need is a shifter which can easily be found here or on sccoa.com
It is still in the XR7 I do not have pics. I can have it out with a days notice.
Thanks
Brian Walter
is this still available?im in mass on the rhode island border so pick up wouldnt be a problem.pm me if my newbie status allows otherwise i'll give you my email.thnks
still available
I haven't removed anything from the XR7 yet, work has been really busy. I will remove when you're ready. You can call me 860 384 0384
thanks
brian
thanks i will call you.this seems almost too good to be true
