Even with hours aside, thats not a lot of money. Its a great car. Pushing on 160K with 5 owners and no carfax history here.
Theoretically yes...but I think it would be cost prohibitive.Could you import it to Germany?
Is that so, likely in partnership with Jaguar?Could you import it to Germany? You would probably be one of the very few on the road. Rumor I have heard is the suspension on these cars was modeled after the 5 series BMW.
I think MN12 development predates Ford's involvement with Jaguar, but they benchmarked against the BMW 6-Series I think.Is that so, likely in partnership with Jaguar?
That's because the LS and S-Type share the same underpinnings.I think MN12 development predates Ford's involvement with Jaguar, but they benchmarked against the BMW 6-Series I think.
That said, when you look at the suspension of a Lincoln LS/Jaguar S-Type, it does look quite similar.
I know that...lol.That's because the LS and S-Type share the same underpinnings.
It's early. You can't expect me to read good this early.I know that...lol.
I meant similar to the MN12. I think they also have that load-bearing lower ball joint which I always find somewhat scary.
They got it from Detroit in 1961 😉That's because the LS and S-Type share the same underpinnings.
And yup, the MN12 had its sights set firmly on the BMW 6 Series. Coilovers and a multilink suspension on an American touring coupe? They didn't get that idea from Detroit in 1989.
Well, mine slipped off as I was pulling. Fortunately that happened a split second after it had reached that notch 2, so everything went ok. But I can't in good conscience recommend that procedure to anyone.I found it quite easy with the tool from the manual.
Oh my, yeah, definitely lucky.I've never had a problem with the trunk lid, even after adding the spoiler to it. I can leave it partially open and it will stay there, maybe it's luck on my part!![]()
Mine too, frankly my trunklid was a little too eager to open before I added the sport wing. I thought about pulling the torsion bar to the next notch since it was kind of a fun party trick shooting straight up with a touch of a button but it stays up fine as is.I've never had a problem with the trunk lid, even after adding the spoiler to it. I can leave it partially open and it will stay there, maybe it's luck on my part!
