Yes you can put 4 fibers on each side by setting down the side gear, start with a fiber, then a steel, fiber, steel, fiber, steel and a fiber a then the shim. Normally it takes two shims to make up the clearance (.070 to 075 shim thickness). With the 4 fiber setup a shim of .040 is common. You need the Ford tool T80P 4946 A to find the shim thickness. There is an alternative method to finding pack clearance I discovered when I produced a video on rebuilding the 8.8" rear end. If you email me
[email protected] , I can give you the measurement process. I'm not sure if adding a fiber will make it live any longer and remember you will likely have to buy two clutch kits to do this job........Ken.
