Which?
  • SPI 4.2 SC
    Votes: 11 42.3%
  • N/A 5.0
    Votes: 15 57.7%
  • Total voters
    26
1 - 20 of 22 Posts
Ok been tossing this idea around for a while now 1) mod the 3.8 or 2) lightly mod a 5.0. Looking for about 300-350HP at or below 5000RPM (the lower the better) with most between 2000-4000RPM.
Plan for 3.8:
99-04 Mustang SPI Intake
Stroked to 4.2
Roots style blowers (via 89-95 SC)
forged internals
Plan for 5.0:
Mail order parts
no stroking
Both plans I'd put new rockers (1.73) and exhaust, and have to run with the 4R70W.
In summary the V6 be a SC 4.2 SPI and 5.0 be a basic stuff form Jegs/Summit.
It would be easier to put a 4.6 in, then to try and put a 5.0 in.
On Probation
It would not be smog legal but I would go the 5.0 route. Here is the reason why. your transmission won't bolt to a 4.6. I don't know how long your trany will last with the power of the 5.0 since it has fewer clutches in it than a v8 trany. If you use a 94-95 mustang 5.0 wiring harness and computer you can still retain the automatic.
With either option the tranny will be getting beefed up. The 5.0 would be smog legal if got it out of a 97-99 Explorer.
Confirmed V6 Nut
Bowez,
When I change motors from a 3.8 in my Bird, I'm going to go with a 4.2L V-6 short block. If I modify current intake and heads, I can bolt them up on the 4.2's short block, no problem.
If I go with splitport heads and intake, I'll use the ones from a 00 Mustang. I'll have to put in a chip and probably swap the computer though.
That's my plan. Your mileage will vary.
And I'm getting 26+ on the highway with ethanol which is the cheapest gas locally. That's another reason to think of a V-6, fuel economy if your car is the daily driver mine is, 20,000 in a year on it.
I don't think anything that makes over 300HP is real gas effiicent., and at that level a v8 would be better.
Jedi Master
a 4.2 would just be awsome, before i bought my xr7 i heavily considering doing that swap to my LS, heck i might still do it someday
with the right set up, man you can take out a lot of cars
I'd definately go with a 5.0, not only can you make more power, but you can make it for less money. In fact I personally would probably opt out for the 5.8L (I always wanted a 351W in my thunderbird)
Confirmed V6 Nut
What did John F. Kennedy say about going to the moon? "We do this not because it is easy, but because it is hard."
Making a v-6 go fast brings out the creativity in a person. All a V-8 requires is a bigger hammer.
You can spend half as much to go with the 302 and get the same performance.
Weight and size, there is not much better than a 302.
Now if you do happen to have some extra funds, and really want a 302 to run build a "302 clevland"
Hey ! i resemble that comment:D i went with the v8 in my car beacause there was nothing there when i started, i love v8s but would of settled for a s/c 3.8 , they are easier to play with , and a tad cheaper to play with .
Discussion Starter #18
Well I'm leaning toward the SC 4.2 SPI, now just have to find some one that makes and adapter for the Blower--and money.
V6Sprout over at sccoa has been working on a lower intake that adapts the roots style blower to the splitport heads for awhile now.
Making a custom lower intake
-Rod
I would do a SPI 4.2L stroker, you could have a 250+rwhp and over 250rwtq with one heck of a flat torque curve for under 3000$. A stang 5speed just dynoed at 265rwhp/280rwtq with a 4.2 with ported heads, intakes, and a cam. Best of all you can retain your stock computer and wiring harness, and have enough power to run mid 13 second 1/4's while having the distintive V6 exhaust note that leaves people scratching there heads. ( I know there are a few Kids with V8 birds around here wondering why I smoked them )
1 - 20 of 22 Posts
