how would i go about doing this on my naturally asperated 3.8 i seen an article on sccoa about it but no clear way to do it on the naturally asperated 3.8
Not sure what this has to do with a 7.3 diesel but the Cheapest method on a 3.8L N/A is the a/c bypass pulley. You can then re-use your existing belt.
When I looked at the belt re-routing suggested on this site, I found that it requires a different alternator mounting bracket than what was on my 95 car. If I had to replace the alternator mounting bracket, i might as well spend that money on a "proper" bypass pulley.
Suggestions on how to delete A/C
http://forums.tccoa.com/showthread.php?t=93468
DORMAN AC Compressor Bypass Pulley: I paid $26.79 back in 2010; it's $27.99 now.
Item #34184
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1140556&parttype=10329
Item #34184
Note that this part fits all mn12. Of course you should double check that by looking up the compressors and seeing their application fitment.
Item #34184
i know of the dorman ac delete but i was more interested in the 89-93 acc. bracket relocation thanks for the info guys
