Trying to decide which weight gear oil to use. I see both 75W90 and 75W140 recommended. Any suggestions on one over the other?
75w90 is what you should use, 75w140 is to heavy of an oil. 1400hp pro stock cars run 75w90 i think you'll be ok. unless your driving a semi truck or dragracing an 8,000hp top fuel dragster they use 75w140 some 80w140. think of it this way: with 75w140 your trying to stuff pudding down a pin hole.....75w90 is way more thinner
How many quarts of gear oil does the IRS take?
If empty, it will take a little over 2 bottles. If you have a trac-loc rear, don't forget to add the trac-loc addivitive. Ford dealers carry little bottles of it and you only need one. IMO, don't use the bottles at the parts stores with the addivitve already in them.
gear oil
All the truck diff manufacturers spec 75w90. Ford put 75w140 in mine. when I change mine I will go 75w90 synth with the friction modifier. If it can handle 2050 ft/lbs from an ISX cummins, I think it can handle my 4.6 torque.
