1 - 18 of 18 Posts
I removed this from one of my projects before I parted it.
Everything worked fine last time used, should be ready to install using your bolts and lock pin.
Ford 3.55 Gear set with Trac Loc unit.
Since this unit was removed from a Mustang it is posted that the 3.55 gears will work as/is but the locker would need a mod to work in our cars.
So I have two sale options.
$85.00 shipped to your door. 3.55 gears and locker
$65.00 mailed to your door 3.55 gears only.
Since PayPal has really made me mad this month, I will only be taking payment via Money Order.
<a href="http://s161.photobucket.com/albums/t230/rcreevesphotography/?action=view&current=IMG_0488.jpg" target="_blank"><img src="http://i161.photobucket.com/albums/t230/rcreevesphotography/IMG_0488.jpg" border="0" alt="Photobucket"></a>
Damnit, I want this really bad...
It wouldn't work with a 7.5" rear end though would it?
No however! I do have an "E" code 7.5'' rear end outside. If I recall "E" code is a 3.27 with a Trac Loc unit.
I can take it apart and pop the trac Loc out of it...
After all Most people are simply looking to end the one wheel wonder.
Yeah, actually. :)
How do I find out my axle ratio? I have a 1989 Thunderbird base....
90% chance you have a 3.27 on an 89 Base.. But if you look on your door jam you will find a little sticker the code under AX is your axle code.
PM me when you find it and I can give you the ratio.
Will do, it wont be tonight though, its cold as balls... :D
Double check the pumpkin itself also. Some early 3.8L cars did come with an 8.8 housing.
Awesome, I will compare to my F-150 and Mustang, both have 8.8"s. :)
Mines very early, MN12 was unveiled 21 years ago exactly in 1988, and my car was built two weeks before that, 12/12/1988. :)
da--it i need to look more often . if you still have the gears and locker pm me , i want them !
My axle code is 5, im not sure whether I have a 7.5 or an 8.8 tho...
1 - 18 of 18 Posts
