Are all 8.8 ring and pinion gears interchangable? I can take 3.73 gears out of any 8.8 rear end and put them in the T-bird IRS right?
yes as far as gears go 8.8 is 8.8!
I was just making sure. Someone told me before that the pinion shaft was longer on the IRS setup. I didn't fully believe him, but I wanted to make sure before I spent any money.
I thought spline count was important, like ours have 28 splines and Mustangs have 31.
Tinfoil hat wearer
The splines for the the halfshafts are in the carrier not the ring and pinion
What if I was to get a Trac-Lok rear end or whatever the limited slip rear-end in the '99+ cobra's, would it have the same spline as the t-bird/cougars?
Clay
No, only the 99's have 28 spline, after 99 they went to 31 spline.
