yes and no
All of the stock SC ones are that way and have traklok.
MarkVIII & Cobra also have 8.8 and the whole housing is aluminum.
The Mark doesn't come with traklok but both will fix our MN12s.
Good Luck
Actually not all SC's came with trac-lok. All 89-93 auto's and 5 speeds came with trac-lok. 94 & 95 5 speeds came with trac-lok. 94 & 95 auto's came with an open differential.
Ok,
Open differential, Trak lock.. wait a minute! how do you keep the oil from spilling, in the open differential? :p
Seriously though, I never did understand which is better.
open differential-one wheel peel (side with LESS traction)
trak lok, positraction, locker-diff. ways to transfer power EQUALLY to both wheels
as for which ones better-some posi, or lockers mainly cause your rear to hop around corners b/c the inside wheel can't spin slower. but all in all, any form of locker or posi is better.
"Posi"
No "Posi" ever came in ANY Ford product. However Eaton does make an aftermarket "Posi" unit for the 8.8" Ford housing now. Trac-Loc is what SC's have (except as noted above).
A Trac-Loc does NOT hop the inside wheel in a turn. The clutch plates in the diff. allow each wheel to rotate at a different speed, once the bias pressure is overcome by the TQ difference from each wheel.
A Detroit Locker remains locked to each axle EXCEPT during the time that is actually ractheting. During that time, power is only applied to the axle that is still locked.
68COUGAR
