I have a question on the 80mm lightning MAF install.
I can obviously tell that you need the adapter from Accufab for the side that hooks to the K&N, but, the on the other side which would connect to my factory violin case is the same size as the MAF, how did yall hook your up?
Pics would help greatly or just descrip would be fine too..
Thanks Alot.
Dave
Real Ultimate Goatse Hunter
I used a knife and cut some of the rubber on the inside out, then pushed and pushed unti lthe MAF finally went into it. Its alot easier to do with the intake tube off the car.
I know that my car is a slightley different year but I used a 99 GT intake tube into the maf, then the adapter, then a 4 inch J-bend pipe which I cut in the begining of the bend to drop it into the fender well. Home-made cold air.
  • Like
Reactions: MarkHO
