1 - 2 of 2 Posts
Sweet T
Where is the MAP, IAT and Coolant Temp Sensor located on this thing? I've got a 85 3.8 that has an intermitant stalling issue after the car is up to normal operating temp.
It also recently failed a smog exam with NO emissions of 3000+ ppm
My first thought there is cats because the car is definitely running rich and has a definite gasoline smell to the exhaust.
Should I be trying to run down a vacuum leak? I don't /hear/ one with the car running, but that doesn't mean it isn't there.
Thanks.
Already up for replacement or closer inspection are the: Cap and rotor, spark plugs, wires and fuel filter. There was a pinkish rust-like coating on the plugs which Beau tells me is indicative of alot of fuel additives. So the plugs and fuel filter are gone. Period.
Any other advice/testing proceedures would be grand. Thanks again.
Yup check for vacuum leaks. Have your O2's checked as well.
1 - 2 of 2 Posts
