here is a link to to the 11.0 pass spinning the tires im working on getting the car to launch the 60fts were in the 1.7x range and we have pulled 1.56 but it was spinnging but not as bad as it does know
The car should run in the 10.70-10.80 range
http://www.youtube.com/watch?v=yrMG1Gn5ny8
the car has a vortech 10 psi kit with a powerpipe afr165 heads and all the supporting mods to go with it
anybody with advice on helping it hook send it my way
Thanks
Robert
Boost Happy
Send me the car and you wont have to worry about it hooking. I thought I was t-bird crazy.
As far as launching the car goes, I watched it launch a few times. If you look closely, you can see the car pull to about the max suspension, then it drops, then it pulls again. Not sure if that is a 1-2 shift or not, but it may be the tires breaking loose.
SWS
Well I've got and airbag for the right rear so hopefully it will make it launch straight and CHE is making me some custom drop brackets for the rear control arms and some custom lower control arms
I know it's got at least a 10.80 in it with that mph
Robert
