i have a 1988 stange and i was woundering can i put an 1988 thunderbird trans in it. cuz i cant a mustang trans no where in my area. i know if it fits i would have to change the linkage but im wouldent besides that would i be abeal to put it in without haveing to change a drive shaft:ztoohot:
As far as I know those transmissions are the same. Might have to change the linkage, but otherwise yes it will work. I am not sure what tooth count shaft came in what vehicle so you may want to remove the extension housing and count the teeth on the output shaft of both. Sometimes a different speedo gear can correct it if they are different. I installed a s/c trans into a friends car with no problems a few years ago.
Alan
