there are two thick wiring harnesses that run along both framerails and split up at the radiator support. i believe these harnesses are for the headlights, signals, etc. the driver side harness has the fusebox, battery wiring and maybe an o2 sensor, and the passenger side has a harness for the maf sensor and o2 sensor. are these two harnesses the exact same for the 3.8 and 5.0 engines?
