1 - 20 of 62 Posts
<div style="background-image: url('http://i249.photobucket.com/albums/gg201/izepyck/Fun%20Pictures/bird.gif');background-repeat:no-repeat;">
<div style="background-image: url('http://i249.photobucket.com/albums/gg201/izepyck/Fun%20Pictures/lightning.gif');background-repeat:no-repeat;">
Thunderbird Supercoupe '89 - '95​
<br>
Cougar XR7 '89 - '90​
<br><br>
Engine
Oil Pan with Sensor '89 - '93 <br>
K&N Air Filter + Oil Kit '89-'95 PIC 33-2033<br>
Exhaust Manifolds '89 - '93 (rf-e9se-9430-da \ rf-e9se-9431-ba)<br>
Crank Sensor Bracket and Bolts '89 -'93 <br>
Inlet Plenum for Intake Manifold '89 - '93 PIC PIC2<br>
M90 Case (Oval Inlet) '89 - '93 PIC<br>
M90 Supercharger Inlet Plenum with EGR '89 - '90 PIC PIC2<br>
Camshaft '89 5speed<br>
CAM Sensor Stalk '89 - '95 -- 2 available (f2se-12a362-aa \ e9se-12131-ba)<br>
Rocker Arms '89 - '95 PIC <br>
Pushrods '89 - '95 -- 48 available PIC<br>
Hydraulic Valve Lifters '89 - '95 <br>
Timing Chain & CAM Gear PIC <br>
PCV Tubes '89 - '93 PIC <br>
Intercooler '89 - '95 (e9se-6k775-bc)<br>
Intercooler Baffle Bracket '89 - '95 (e9se-6c6460-ac)<br>
EGR Bracket '94 - '95 <br>
Intake Manifold '89 - '95 PIC<br>
Lower Intercooler Pipe '89 - '95 <br>
Oil Pump High Flow SC Stamped '94 - '95 PIC (f4se-6604-bb)<br>
Oil Pickup '89 - '93 (e9se-6622-bd) <br>
Accessory Bracket LH '89 - '95 <br>
Air Silencer \ Water Arrest '94 - '95 (f4se-9f763-ad) <br>
Motor Mounts '89 - '95 (e9sz-6038-a) <br>
Vacuum Hoses '89 - '95 * <br>
Belt Tensioner (Supercharger) '89 - '95 -- 2 available (e9se-6b209-ha) <br>
Belt Tensioner (Serpentine Belt) '89 - '95 (e9se-6b209-ja) <br>
Belt Tensioner (Jackshaft) '89 - '95 (e9se-6b209-ka) <br>
Power Stering Pulley '89 - '95 (e9se-3d673-aa) <br>
Jackshaft Pulley '89 - '95 -- 2 available PIC (e9se-8a617-ba)<br>
Crank Pulley '89 - '95 (e9se-6312-ca)<br>
Alternator Pulley '89 - '93 <br>
Water Pump Pulley '89 - '95 -- 2 available (e9se-8509-ca)<br>
<br>
<br>
Drivetrain
AOD-E Miscellaneous Parts '94 - '95 <br>
Transmission Crossmember '89 - '93 <br>
B&M Ripper Shifter 5speed<br>
Driveshaft for AOD <br>
Slave Cylinder with T.O.B. '89 - '95 -- 2 available 5speed<br>
IRS Knuckles -- LH & RH PIC <br>
Half Shafts -- ABS & NON-ABS (e9sw-fb2s032791) <br>
Pressure Plate\Clutch Disc '89 - '93 <br>
Rear Differential 3.27 * (515d 3 27 88 4a21)<br>
Speedo Gear 2.73 -- 2 available PIC <br>
<br>
Exterior
Rear Bumper Foam '94 - '95 <br>
Rear Bumper Decorative Insert '94 - '95 <br>
Cowl Covers '93 - '95 (f3sb-63018a14-ah \ f3sb-63018a15-agw)<br>
Rear Driveshaft Loop '89 - '95 <br>
Drive Shaft\Heat Shield Support '89 - '95 -- 2 available <br>
Hood Latch Puller '89 - '95 <br>
Muffler Brackets '89 - '95 -- 3 available <br>
Windshield Wiper Arms '89 - '93 PIC PIC2 PIC3 <br>
Fuse Box Cover (Engine Bay & Under Dash) -- 2 available PIC PIC2 * <br>
Front Subframe Support Bar '89 - '95 <br>
ARC Sensor Covers '89 - '95 PIC * (e9sc-18a179-a / e9sc-18a078-ac)<br>
Miscellaneous Badges Thunderbird\Cougar XR7 <br>
Gas Door With Hinge PIC <br>
Rear Bumper Support '89 - '93 (e9sb-17e855-aa) <br>
<br>
Interior
Ashtray '89 - '93 -- 2 available PIC <br>
Trunk Lock Cover '89 - '95 (e9sb-6343243-aa)<br>
<br>
Electronics
Starter Solenoid '89 - '93<br>
ARC (Auto Ride Control) Computer -- 1 available PIC <br>
Fog Lamp Switch '89 - '93 -- PIC PIC2<br>
Firm Ride Switch '89 - '93 <br>
CAM Sensors '89 - '95 <br>
Alternator 110 AMP '89 - '95 <br>
Rear Defrost Switch '94 - '95 <br>
MAF '89 - '95 -- 30# & 36# calibrations PIC <br>
Coil Pack 3.8 SC '89 - '95 -- 3 available PIC<br>
EDIS Module '94 - '95 PIC PIC2<BR>
Headlamp Dimmer - PIC PIC2 <br>
Inertia Switch PIC <br>
EEC-IV EEC calibration code L0E1 -- '90 5speed PIC (f0sf-12a650-l2b)<br>
Idle Air Control Sensors '89 - '95 -- 3 available <br>
Low Level Oil Sensor '89 - '93 PIC<br>
Head Lamp Bulbs '89 - '95 All styles available<br>
Deck Lid Actuator '89 - '95 PIC <br>
Climate Control Relay PIC <br>
BAP Sensor '89 - '95 PIC <br>
Pressure Switch for Teves II PIC <br>
Gauge Cluster '89 - '93 (f0sf-10c956-a)*<br>
Wire Harness DIS\CAM\COIL '89 - '93 <br>
Wire Harness INJ\O2\EGR '89 - '93 <br>
Wire Harness Hood Light '89 - '95 (f2sb-15k702-aa) <br>
Fan Motor (Radiator) '89 - '93 (e9sf-8k621-ba) <br>
<br>
Cooling
Coolant Hoses Miscellaneous <br>
<br>
Fuel
Fuel Pump 190LPH (Stock) '89 - '95 <br>
Fuel Injectors 30# '89 - '93 -- 6 available PIC<br>
Fuel Rail (Three Hole & Two Hole Designs) -- 2 available '89 - '95 PIC PIC2<br>
Fuel Rail (Parts Only) '89 - '93 *<br>
Fuel Pressure Regulators (Three Hole & Two Hole) '89 - '95 <br>
<br>
Steering
Rag Joint '89 - '95 PIC * <br>
Power Steering Pump EVO '89 - '95 -- 2 Used 1 NEW (rf-d8a0-3d609-ab)<br>
Steering Shaft (Engine Bay) '89 - '95 <br>
<br>
<br>
Many parts not listed, inquiries welcome.<br>
All parts shipped next business morning USPS or carrier of your choice.<br>
<br>
<br>
Please PM or send email <br>
<br>
<br>
Legend
* Blue asterisk indicates low priced inventory, inquire for details.
* Green asterisk indicates flawed item, inquire for details.
* Black asterisk indicates that local pickup is strongly preferred.
<br>
Buyer’s responsibility to schedule pickup for items tagged with a black asterisk.<br>
These items will be placed on a pallet and tied down securely.
<br>
Positive feedback can be found here
http://www.sccoa.com/forums/showthread.php?t=116012
<br>
<br>
<table width="100%" border="0" bgcolor="#FDFDFD"><tr style="font-size:xx-small"><td style="color:#FDFDFD">
thunderbird,supercoupe,cougar,mustang,XR7,LX,GT,SC,cobra,sport,mark viii,mn12,3.8,M5R2,3.8SC, super coupe
<!-- All Keywords should be on the above line --></td></tr></table>
Looking for a rear sc bumper cover. If you have one and are willing to ship let me know how much to TX 78552.
I think I replied already but if not I don't have any rear bumpers, thanks.
bump
bump..... thanks Ray
updated list
Updated list......
bump..
Steve, many thanks, I will have this shipped tomorrow morning.
Updated list, added a ton of pictures along with a legend to help with the common questions I've come across.
bump.........
Bump
Thanks Dave :thumbsup:
bump.....
Derek, thank you again....
list updated
thanks Abraham :)
bump.................
Discussion Starter #14
Thanks Charlie, will have your part shipped out asap. :)
bump...........List updated
Discussion Starter #15
bump to the top.........
Discussion Starter #16
Updated list, thanks Bird of Pray!
Discussion Starter #17
bump
Added a few parts to the list
Anyone need a late style blower (rectangular outlet) for their Thunderbird or Cougar?
Easy upgrade over the early style M90's
Discussion Starter #18
updated list.........
Discussion Starter #19
bump....
updated list.......
Thanks guys, your items were mailed out yesterday.
Discussion Starter #20
Thanks James, valve covers have been shipped.
1 - 20 of 62 Posts
