1 - 1 of 1 Posts
How do you remove the door latch on a '89 tbird? I've got everything loose except for the door lock actuator motor and manual inside lock rod.
If I can get either of those rods unhooked I can get it out.
How do you remove the door lock actuator motor? Is it one big pop rivet on the door jamb edge of the door?
1 - 1 of 1 Posts
