So i was runnin the car hard and it started losing power i got home car died wouldnt start likeno compression i could keep it started by feathering gas pedal but it wouldnt idol so i stared it up this morning and it fired up but sounded kind of weird but any advice please
Vacuum leaks.
Since it's a 3.8SC, an automatic assumption is "blown head gasket".
Time to start doing basic troubleshooting before you start asking "What's wrong?"
I suggest grabbing the Ford Service Manual that you should have, and starting to troubleshoot the problem(s).
And something else - what has been done to it recently? Plugs? Wires? Coil pack? How old are the vacuum hoses? Etc.etc.
Compression test is fairly easy to do and will give you some answers. And check the condition of your fluids, of course!
no compression
well fluid is fine its a well maintained vehicle replaced some hoses full tune up at the shop new alternator had a diagnostic ran and said i had a vacuum leak but could not find it and it didnt act like it either but i have no psi boost when i hit the gas the car ran the next day dont not right after this prob i do have a spare supercharger setup for this and was gonna instal it and see if that fixed the problem
13's or Mildly Broken
Since it wasn't mentioned, I'd check the harmonic balancer. Although after trying to read you're second post - I don't think the balancer is the problem. Especially if you were able to drive it the next day. When the balancer broke on the 94, it would barely run.
Car is dead
So it was a compression problem at first so i started the car up to see if i could identify the vac leak on the supercharger so after it warmed i rev it a up a little to see what the sound wasand the car died cranked it agaun and it died immediately tried to crank it nothing kept tryin and the naterry started to smoke i am lost with wats happening ot seems like total faluire with the engine
IDK how you would lose compression that fast unless it overheated or something. Sounds like you have a few issues going on.
On the boost, that could be on your ignition system - or a vac / boost leak, it wouldnt be from the supercharger itself, more likely the IC tubes leaking.
Starts and dies .. I could check for codes to see if anything is funny, could be a Cam position sensor, ignition module, etc.
A lot more information on these supercharged cars is available on the SCCOA website.
