1 - 2 of 2 Posts
I figured I would ask here prior to the sccoa. I swapped a lot of parts that I had left from my SC over to the LX. I have a lot of noises like binding in the front end. I swapped the spindles from the SC to the LX because they were powder coated along with mustang hubs and PBR calipers. I used the same sway bar end links as what was on the SC since they went with the spindles and brand new. I know on the sc when you swap the later spindles to do the brake swap you have to use the later sway bar links. Just wondering if its not the same for the LX.
I am just trying to figure out where the noises and binding is coming from. I dont see any wear marks or rubbing anywhere.
Moved to Suspension. :)
1 - 2 of 2 Posts
