this car i got a new dis,crank sensor,cam sensor coil and it still hard to start like it jumped time but when it dose start it runs good im stumed please help thanks
could be a fuel problem, have you checked the pressure at the rail?
how long has it been since the fuel filter been replaced?
perhaps since you changed all the ignition parts you should change the more common wear parts like wires and plugs.
if u havent fixed the problem,change the ignition module
mike
sc
check and change ur ing nition mod, check the presure at the fuel rail. 2 thinghs u have to check.....spark, fuel.
