Will the 93 Mark gas tank fit my 94 Bird? Are they both 19 gal?
-Rob
it should fit, but i cant for sure be certain, they are both 18 gallon tanks
Fuel pump is different for the Mark.
Gas tank is the same, the 93 Mark tank will go into your 94 Tbird no problem.
Cool. It's been so long since I looked at my bird's fuel pump module, I can't remember if it looks the same as the mark one. I wonder if my bird module will swap into the mark tank. I assume that it will slide right in place of the lincoln one. Thanks you guys
-Rob
