So what is everything that's needed to do this swap? I think I got all the big stuff, but I just know I'm missing some small things. Here is the list I've made from searching:
Am I missing anything?
Does the 96-97 intake tube connect to the 94-95 air filter box and MAF assembly?
Are any of the sensor connectors different?
I finally found a T-bird in the junkyard and am trying to get what I need.
- Fuel Lines (filter to rail)
- Fuel Rail
- EGR Pipe
- Throttle Cable
- Cruise Control Cable
- Throttle Body Adapter/Plenum
- Throttle Body
- DPFE Sensor Bracket
- EGR EVR Bracket
- Air Intake Tube (air box to throttle body)
- IAC Valve Silencer
- Vacuum harnesses
- IAC Valve
- EGR Valve
- Throttle Position Sensor (can be re-used from 94/95)
- Fuel Pressure Regulator (can be re-used from 94/95)
- Coolant Temperature Sensor & Sender (can be re-used from 94/95)
- Intake Manifold
- Gaskets
