1 - 1 of 1 Posts
I have a black gauge surround bezel and stereo bezel for a 94-96 bird.
The gauge surround has a little rubber peeling on the side not a big spot and where the upper screw goes in a chunk fell off but if you can are good with a dremel and glue you can make it look near perfect with a donor piece since the onlyt part missing is the recessed circular area you won't see much. All the bottom clips are there except for one that fell part on the stereo bezel and the other has a crack in it so it needs some glue but these are hidden so it doesn't need to look perfect. Pics show all there is.
Its $35 shipped anywhere in the 48 states
1 - 1 of 1 Posts
