I know my flasher needs replacing and I have already purchased a replacment. Where is it? I assume under dash, but where? Any help would be appreiciated
Is this because your rear lights are not working? Try pulling out and back in your EM flasher button.
If that does not work the flasher is located under the left side instrument panel. It is behind a cover.
In your fuse box.
Raoul Duke
Just in case you haven't yet researched this, it could also be your MFS.
3rd Gear Chirper
93pimpin said:
In your fuse box.
Nope. It's mounted on it's own integral bracket, looks exactly like a relay. Black, square, with a push-on connector. It's near the fusebox, but not actually in it. Screwed onto the dash bracing...if you have autolamps and know where the autolamp relay is, then look next to it and you'll see the flasher.
I was thinking of my Bronco, and I think my old 93 Cougar.
lh side of the dash , on the brace
no it is under left side of dash take of the lower dash panel and kick panel it right above your hood release on the kickpanel easyist way i found to find it was turn on the turnsignals and listen for the tick and follow it .you can feel the relay ticking when you touch it.
like i said....
