i would like to utilize the bulbs from 94-5 (and i think 96-7) in my 93 headlights. i know the bulbs wont fit in the back of my headlights, i will worry about that. im mainly concerned with the wiring aspect. what all do i need as far as wiring is concerned?
Dim Bulb
9007 headlight wire harness. Take exiting ground, low beam & high beam and splice them in. Corner bulbs are fine as they are. You'll need to get the "just pretty" light holders/wire harnesses from another car, then tap onto the ground & driving light wires from the corner bulbs.
Dim Bulb
the secondary running light bulbs, the ones on the insides of the headlight housings
