1 - 19 of 19 Posts
1994 XR7 , 46 most every option. 66.000 miles. rustfree, from washington state.
nos or very low mileage 94 xr7 cougar speedometer wanted. thank you! irv toms
Check your Ford dealer. Sometimes the parts guy may have enough time to look in their old crash books. I have had excellent luck finding N.O.S. window trim and stock radiator hoses.
I have one with 52,000 on it.
Discussion Starter · #4 ·
i have too, over the years. they also check vintage parts, who buy their osi parts.
Isn’t the ‘94 Cougar speedo the same as any 94-96 MN12 speedo?
Discussion Starter · #6 ·
i havent seen a 94-6 tbird to tell you. is the lx and sc speedo the same?
1994 Cougar XR7 DOHC/5-Speed
The 90-96 6 gauge cluster speedometer LX, Sport SC (90-93) and Cougar speedometers are the same.
What’s your reason for replacing it? Broken odometer? If so there’s a strong chance a NOS one won’t be any better, the material used for the gear drive seems to get brittle with age not just use, you’re better off rebuilding what you have
Do these assemblies have the PATS system?
Discussion Starter · #10 · (Edited)
odometer just started working on and off. could just be on a morning or afternoon break.
edit: i meant to say the trip odometer started working on and off driving it wed afternoon.
Discussion Starter · #11 ·
Your gears are breaking just rebuild it and you'll be good to go.
Discussion Starter · #13 ·
the speedometer part works fine. just the trip odo intermittently works..
Discussion Starter · #15 ·
if the gears connect both the trip odo and main odometer shouldnt both not work instead of just intermittent trip odo ?
Discussion Starter · #18 · (Edited)
my ford dealer gave me a dealer who has an nos one yest afternoon. ordered it. last one at a dealer. nothing at vintage either.
Discussion Starter · #19 ·
well, the gears in my old one look perfect. what the heck ?!
will see what the new unit does. its in, just not driven yet.
1 - 19 of 19 Posts
