I bought this 94 sc hoping i could fix it myself and like my 3.8na in my 93 this one is making noises and the timing is off, so see what you guys think and let me know what you think the noise is and how bad off my motor is, thanks
I GOT THE CLIP TO 3 MEGS NOW, PLEASE HELP ME!
YOU HAVE TO RIGHT CLICK AND SAVE AS TO YOUR HARD DRIVE THE FILE
http://members.cox.net/smitty1258/tbird94%20009.mpg
also i was wondering if i can use the starter from my 93 3.8 n/a on my 94 sc?
tyler
Sound-Xtreme
sounds like it is something on your pully system....id start to check there..kinda sounds like an idler pully..
but to check these things you can grab a screw driver and touch the metal part to the alternator, idler arm..etc and stick your ear to the plastic part and listen to see if you can hear the noise..
its not the pullie system, checked it, i was thinking water pump, supercharger, flywheel, and the timing is way off i kno wthat also for sure, but cant figure out what the squeeling noise is.
Tyler
if it is the balancer, the best way to check it is by removing the belt totally and starting the car for only a little while. and if the sound is gone, its not the balancer and might be s/c or the pump.
