1994 XR7 , 46 most every option. 66.000 miles. rustfree, from washington state.
anyone have a valve body or separator plate from a 94 4.6 trans ?
would like one if possible. let me know. thank you! irv toms:)
At this point, most have upgraded, so there should be some around.
The pre'96 transmissions had the most stuff removed; by 2002 they had added it all back in.:)
The one piece teflon seals are actually chevy parts, but they make a hugeer difference than anything else I've done.
I'd bet Supergordo might jmod yours for a fee, if you ask nicely.:)
Discussion Starter · #3 ·
i have a friend to help[do] it thought if i had one done it would go faster.all i dont have is the bits and an od servo, whic probably isnt needed
check how much 'wobble' is in the shaft of the od piston; it can be helped by the sonnax part, but it Will be a problem; it drops pressure on something important.
A local guy showed me that; I showed him the teflon trick, and he put my next transmission in free. , lol.
I didn't mention that if the wobble is bigger than the compression of the o-ring, you need a new transmission case.
  • Like
Reactions: irvin
Discussion Starter · #5 ·
the pin kit is sitting here. thank you !
Discussion Starter · #6 ·
whats the teflon trick ?[inquiring mind]?
