First off, i have a 95 tbird with the 4.6 motor and its been running real rough...
its misfiring real badly and sputtering, very strong unburnt fuel smell, lots of fluid from the exhaust and i hear a light chattering coming from the engine bay every now and then as well as a whistling sound when the throttle is depressed.
under hard acceleration the motor runs good after warmed up but right back to a rough idle/acceleration to where it wants to die when the RPMs drop.
the plug wires are basically new as well as the spark plugs, fuel filter, i swapped in a used but good MAF - cleaned it before installing it.
every cylinder is getting spark (i pulled each one with the engine in idle and verified spark)
Where do i start?? i dont have the cash right now to take it in to a shop so i need to fix this myself.... help
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
TCCoA Forums
