Hi ya'll
Been gone for a while but now I am back. Got a 95 Cat w/4.6 and here's my issue. This spring I changed the thermo and flushed the system out several times and replaced the coolant 50/50. On my trip to town on the interstate (20 miles) and if the temp is above 75 or so, the temp gage will go to between the m and the redline. I kinda thought that I may need a new radiator as it may be stopped up, but didn't have the funding for said project. Now with temps not getting above 70, the temp gage stays halfway between the n and the cold line with little heat. I can not make the temp gage go any higher or get the heater any warmer. I am going to replace the radiator this spring b/c it has a hairline crack in one of the tanks. Any suggestions?
Thanks
BTW-Lucas Oil Treatment works great on helping put a band aid fix on the valve stem issue
Thanks
