So that cheap chrome imitation is coming off my grill too....
I've been thinking aobut takeing it off and just painting it a glossy black. Easy question....How do I get this thing off? Anyone else do anything with the 94-95' grills? Thank you.
The grill has a few screws on the top then I believe it is one metal tab holding it in that you can pop off with a screwdriver. Now if you want to take the Cougar emblem out of the grill you will have to cut it out from the back.
Thanks. Sounds easy enough. Now how bout' the painting?...should I remove the crappy chrome from the grill and use a high gloss spray paint. Thats what I'm thinking.
Raoul Duke
It depends on the way the chrome is applied to the grille at the factory.
On the older Cougars (Fox), it was a huge PITA to remove it. I believe it was applied to pot metal.
You may just be able to sand it down, prime it, and paint it.
Ask cougar_guy04; he painted a '96 grille.
Just sand it good to prep the surface. No need to take the chrome all the way off. just take the shine out of it. I sanded with some 180 grit I believe and stepped my way down to some really fine stuff, 1000 grit I believe. Then I put a coat of primer on it and some more fine sanding. I used some paint that matched the exterior of the car, I think it was duplicolor, and then I clear coated it. It came out pretty good.
^Thanks! I'm doing it tomarro and will get pics to see how it turned out. I don't know, I was never a big fan of these grills (96-97 looked fine though) Theres just to big a gap between the hood and grill i guess.
