has anyone ever removed the headliner from the car with a sunroof mine also has the access door in the back for the sunroof motor it looks like its attached to the rim around the sunroof opening after you pull the trim around the opening also down how would you take it out of the car to install new material on it and reinstall because the only way I see to do it without messing it up would be out the front of back window
any ideas
thanks
cr
1994 Cougar XR7 DOHC/5-Speed
pull away the rubber weather stripping first and work your way from the back forward popping out each clip. As long as you’re gentle the clips shouldn’t break. The rear sail panels are harder, I’ve never broken one but sometimes the clips on the C pillar will pull out of the plastic or hang up on the sound deadening during reinstallation
