1 - 20 of 25 Posts
· Registered
1995 40th Anniversary Edition 4.6L
Couple of huge hurtles but able to make some good progress recently.
Finished cutting/boxing/welding K-member (since no aftermarket when started) and installed engine with homemade engine mounts. Lowered steering rack with off set bushings and got engine to fit where the 4.6 sat.
Headers are from Ultimate Headers (S550 Mustang), and they helped move a couple tubes to fit the TBird perfectly.
The pics of engine in are deceiving, it does not stick up that hi, however, the TBird front clip is real thin going forward, and the engine is high above fenders. Looking at new hood to fit.
I have the Griffin 3 core radiator in and intercooler also in. The radiator I moved one inch forward (into radiator support), so I could make room for reverse facing alternator and aftermarket fan. Coyote front timing cover is bigger and takes up more space forward. Also have the trans cooler/fan installed, just need to do plumbing for trans cooler and intercooler.
Also finished the fuel supply, had to get to a bigger fuel pump, 455lph vice 255lph. The new pump has a bigger bottom than stock pump so I cut bottom of hat, return tube, and welded a new mount for new pump. I used factory hard lines, press/return but replaced press line for a 3/8 line. All lines, filter/check valve/regulator all installed and done.
Moved on to the rearend so I could finish the bigger items and order the new drive shaft.
I did some powder coating on diff and LCA's, and rebuilt/renewed everything.
3.73 gear with the Tac-Loc and axles from Drive Shaft Shop (ordering drive shaft from here also). DSS has been real good to work with, and they list axles specific for our TBirds. I got the 31 spline axle set. Also made a new ID tag for rearend, copy with my initials and date done...lol little fun.
· Registered
Discussion Starter · #4 ·
After Christmas will order drive shaft, finish rear and brakes, front spindles/brakes, then down for plumbing and electrical, plenty electrical.
· Registered
1997 thunderbird LX
No mods to the tunnel, fits really good with room to spare. I put the coyote in same position as 4.6 and the rear cross member/trans mount fit in factory position also.
That’s fantastic news! A lot of guy on here are worried about modding the tunnel to fit. Seems like it’s a Str8 coward swap to me. Thanks!
· Registered
Discussion Starter · #10 ·
I think it will be straight forward also. The length from engine mount plates to the bell housing is same on 4.6 and coyote. I'm sure I have the engine in same place as 4.6 on this one and it fits well. I used a 6R80 trans mount adapter from Summit, and it aligns with factory cross member.
· Registered
Great build! Exciting to see this moving along.
Honestly, the most impressive work here to me, is what you did for the radiator and moving it forward the way you did.
· Registered
Discussion Starter · #17 ·
Do you have any pictures from the cross member?? Where did you cut and how did you box it back in.
I'm very interested in that
Thx
The cross member just needed a little more angle on sides, then straight down in front. Then box it up.
I should have grinded my welds, but they are strong LOL. It took a while for all trial fits, measuring, cutting, repeat....etc.
· Registered
Discussion Starter · #20 ·
On to mounting brackets for some accessories. These are power steering reservoir and Whipple coolant reservoir.
Takes up a lot of time to think of, build and paint. These two are mounted to PDB and shock tower. Still have to figure out radiator reservoir, PCM, and air filter.....
1 - 20 of 25 Posts
