1 - 20 of 28 Posts
Right here is an excellent write-up with pictures. I am partial to that setup.
You don't have to but if you don't there is a gap between the headlights and the hood. I have a picture of mine before I got the hood on:
The whole passenger corner got smashed. That was my justification for doing the swap.
cool what about the bumpers, are they interchangeable? i dislike how the front bumpers just get so thin and thats it, seems like the 96/97's have more to them.
Someone correct me if I am wrong, but I think you can put a 96/97 bumper will bolt right up to a 94/95 car. If you want a 94/95 bumper on a 96/97 car you have to swap out the "honeycomb" stuff behind the bumper because the 96/97 bumper sticks out farther.
CEO, WT Club
Yes you need to swap out the bumper support, as well as the cover. 8ate8 is right, if you dont swap you need to cut. I personally like the '95 cover better. :D
-Joel
they do make a cobra R hood for the 97 correct? and that hood will work on a 94 with the different latch release? i was actually thinking about going into a full pin on hood...
CEO, WT Club
Yes they do make that hood. It will work on a 94 with the headlight conversion... you dont even REALLY need the latch release... guess that doesnt matter with a full pin on though.:D
-Joel
My '93 has a '94 bumper, '96 headlights and VFN cowl hood.
The '94 bumper was an direct bolt-on with the hood and lights. I don't think the '93 bumper will fit the lights correctly.
I used the '96 header and '93 hood release. Just drilled a couple small holes for a zip tie to hold the lever in place. I will probably eliminate the secondary latch now since I have hood pins.
You might research whether the '93 bumper will work.
Has any manufacture ever produced or will produce 95 style clear headlights for T-birds and cougars? Swapping the whole front end for lights is kind of expensive.
Nope.
I agree, but it doesn't just give you clear lens... it makes the whole front of the car look different. You can usually find all the parts (used) for ~$300. In my case I had to replace several parts anyway so I figured... why not? It would have been just as expensive to put it back stock.
CEO, WT Club
$90 new headerpanel from Ford
$75 for Headlights
$40 for clear corners
$50+20 service charge to Melon for hood;)
$275
That plus gas to pick up the hood from Melon in NE, and I have a much nicer lookin birdie.
-Joel
VERY nice homer.... now... im doin same..... jus comin up w/ money... lmao looks very good imo...
I am having problems with the 95 bumper fitting overtop the 96 header between the headlights. I am assuming that I need to trim some of the header away, right?
1 - 20 of 28 Posts
