1 - 11 of 11 Posts
so far i been doing a lot of upgrading for my 91 sport: under 100 bucks
96 tail lamps 22.00 dollars a set
96-97 headlamps and corners 6.00 for corners and 12.00 for headlamps
94-97 doorpanels 7.00 a piece
94-97 lamp switch - free
Saturday hood 35.00
Bumper may come soon i know i have a gap where the grille goes but i may just make to look like a 99 mustang grille with the bird in the middle.
damn where are you getting all this stuff for so cheap from???
Its a dirt cheap auto place every car. here some pics
front with 97 lamps on 91
97 tails on a 91 I might have to change the trunk.
Orochispice,
Are you using the stock '91 header panel or a '96-97 one? If it's the '91 panel, how do the '96 lamps bolt up? What changes to the header panel or lamps did you do to make it work?
-Allan
odd a gap around the newer lamps.
Well, did ya modify the headlight panel or what?
-Allan
I had to modify the 91 header panel. I lines up with the holes and i bolted them up i still have to get the head.
1 - 11 of 11 Posts
