1 - 20 of 22 Posts
Well, Dunno what happened, doesn't look like the hood got shut all the way? Well now it won't open. It looks like it's popped but not opened but the lever doesn't move. Upon getting up in there with a flashlight I see the latch and the "F" shaped piece of metal. The hood is resting on the top of the "F" instead of the middle. Prying up and jumping down doesn't work, anyone got any ideas?
Any bolts you can get to? I don't think you can remove the grill without opening the hood. Might be able to if it's not shut all the way.
It's not shut all the way, I can get a crowbar to the latch but I can't move that "F" shaped piece of metal. Assuming I can get the grille off, what do I need to do?
Full Metal
is there any way you could get a pic? i'm having a problem visualizing which piece of metal your talking about., oh wait, n/m i think i know what your saying, can you pry up and try to move the the f shaped latch/piece of metal to get it unstuck?
The latch, the part that moves to catch/release the hood after you pop it. lol
<img src="http://www.mn12tbird.com/misc/trucklatch.jpg">
Full Metal
yeah that's what i thought it was. can you get somebody to pull the release while you attempt to move it up and down? it might help, it's in a bad bind, other than that beat the crap outta it with the prybar.
Posted on FSBronco. Maybe get some help there. I'll let you know, if you don't get it fixed sooner.
I'll try that tomorrow when it's not 44* outside brrrr..
Thanks, I didn't know any truck places to register for. lol
sd, you might be able to remove the 2, 8 mm screw that hold the latch on thru the grill. you wont be sucessful in the removing the grille with the hood down, theres screws all long the top edge of the grille
Same one rancherlee is on. www.fullsizebronco.com which is the same as the F-150, mostly. As far as this is concerned. Then there's the Centurion, which is the F-Series with an extra row of seating and a Bronco cab grafted on the back. Kinda like the Suburban to the Tahoe/Blazer.
I just thought maybe it'd be close to mine, which gives full access to the latch:
SD can you whack the F shaped latch towards the passenger side? Maybe the cable is bound? Lay on the ground and look up from underneath if possible. The secondary mechanism could also be the culprit. I'll check my 95 in the morning when it's light out if that'll help.
Refrigerator Raider Hater
On my truck I have to push the hood down and pull the lever. But my "F" points to the other side.
Discussion Starter #17
Yeah, that's how you open the hood when it's not stuck. lol The lever in the grill hasn't even sprung back to be able to be moved though, and the hood doesn't budge.
Couple replies:
abra said:
dont know if this help, never tried it on a bronco
can they reach the top 4 bolts on top of grill, i think if he can remove the grill he might be able to figure out the problem ezr
Clarko said:
Try this:
Have one person open the latch from inside the rig.
Have someone else move the hood to the driverside as much as they can while pullling up.
Discussion Starter #20
10mm bolts and yes, yes I was. :D The back latch that you release from the grill had gotten bent back and was hanging up the hood.
1 - 20 of 22 Posts
