1 - 12 of 12 Posts
I have a 96 Tbird 4.6L. After replacing the alternator with an Oreillys new and not remanufactured unit and a new Oreillys AC compressor my car eats one rib off the serpentine belt. I was pretty sure it was the alternator pulley so I ordered the correct alternator pulley from Rockauto.com. It is still eating belts? I did do the AC compressor around the same time but it is the alternator that the belt tracks too far forward on. Anyone else have a simular issue? I am guessing it's the Oreillys alternator but I figure I would check here first.
maybe the new alternator was cast a bit too long(incorrect)?
Also,
check all your other pulleys for play and wobble.
Also,
I replaced all the pulleys as well. I guess I should have posted that. The belt runs on the front of the alternator pulley. It's like the pulley needs to be spaced out an 1/8" or so. I am hoping someone bought a new Oreilly's alternator and had a simular problem. I would then just buy a different alternator. I just don't want to waste the money if the alternator is not the problem. It took me a little while to realize the belt was getting eating so I had returned the original as a core.
Do you have a way to compare it to the old one?
Stephen
I wish I did. I bought the car with a remanufactured unit on it. The battery light was on so I replaced it and used it for a core. I didn't notice a problem till the next time I opened the hood. I really thought they sold me the wrong belt since it was one rib short so I bought a new belt. And it happened again. I went back to Oreilly's and they said I should have kept my original pulley. That's why I bought the one from rockauto. I installed it with a new belt and it appears to sit out a little more. The car still eats belts. I just noticed that my power steering pulley has play in it and doesn't appear to line up. Now I am wondering if the power steering pulley got messed up from the non-Ford pulley and since it is now off it is my problem? The power steering pulley appears to be a press on type. The belt goes from the alternator to the power steering.
use a long straight edge to check alignment of the faces of the pulleys.
You might find the slignment problem.
A laser edge finder is useful too if you happen to have access.
r
r
Yeah it has to be an alignment issue. I'm just not sure if it is a poorly made Oreillys alternator? Or maybe they sell more than one for the 4.6? And they sold me the wrong one? I guess I will pull the alternator a d take it back to Oreillys. I will have them pull another to compare. If they are the same I will try autozone.
Try napa new alternators.(if you have a napa nearby). I never had an issue with them.
did you replace the tensioner?
Yeah when I purchased the car it needed a waterpump. When I replaced that I installed a new tensoner and belt pulleys. It looks to me like the alternator sits a little to far back. The way it bolts in there is no adjustment. It's hard to tell by just eyeballing it. When the belt losses a rib the alternator is the only one with the gap at the back of the pulley. The rest of the accessories have the gap at the front of their pulley.
If the alternator sits too far back, perhaps you could shim it forward using a washer? One time I made shims from bronze bushings to move an alternator underdrive pulley forward from the alternator case. It went on the shaft before the alternator pulley did. Just a tip too, always compare your alternator pulley to the new one before sending in the core. On reman units you may end up with a much different diameter or number of grooves. I've even recieved v belt pulleys when I needed serpentine pulleys on some older style ford remans.
-Rob
1 - 12 of 12 Posts
