Hello Everyone,
After years of the Tbird setting in the garage (and not coming here) I decided to start using it as a DD again. In this time it seems that AED has went out of business and I can't find any info left on the web from their installation manual. I think that the fuel pump went out on my car, and I can't remember how big a pump is needed with the supercharger. Anyone know this information?
Discussion Starter #2
Just found the supercharger section, so if someone wishes to move this to the correct section or leave it here.
255 lph walbro :)
255lph sounds correct, now that I hear it. :D Is there a reason to get a HP pump over the standard one? The regulator that I have is only set to 35psi anyway.
With the key in run, I should have 12volts at the inertia switch on the not green wire?
