But they're both not MN12s? It'd be kinda misleading thread title.You could always change the thread title to "build(s) thread"!
That’s neat, Looks like it keeps the stock LCA pivots but replaces diagonal reenforcements the strut rods mount to.
Yeah it’s a nice unintrusive solution, I didn’t know anything like that existed. It’s actually cool working within the confines of the stock layout, like something Shelby would have done back in the day if they had thought of it.Yep. Anything more and I'm pulling the engine and cutting the car up and welding in a crossmember, and it would cost more also. I wanted to make some improvements to the fairly bad stock suspension without spending a ton of money.
I would have assumed you'd convert it to a saginaw box, I never liked those ram ones
All Ford’s prior to 1971(ish) used that setup, the boxes are effectively manual, just with different ratios, Ford’s better idea was using a hydraulic ram to push on the linkage for boost rather than have it be integral to the box. Corvettes used this setup too, weirdlyI've never seen steering gear like that; 69 what?
And Corvettes until 82All Ford’s prior to 1971(ish) used that setup, the boxes are effectively manual, just with different ratios, Ford’s better idea was using a hydraulic ram to push on the linkage for boost rather than have it be integral to the box. Corvettes used this setup too, weirdly
One other thing with the power box also is I would have to modify my tilt-away steering column which I really don't want to do. At this point that column setup itself is worth about $1,500.I would have assumed you'd convert it to a saginaw box, I never liked those ram ones
