1 - 10 of 10 Posts
Im planning to make the center part of my taillights light up like on the thunderbirds. I have some thin red led strips that would work perfectly, but i was wondering if its possible. Does anyone have pics of the rear middle section off and without the lense cover on?
ahh, that was to a 89, which has more room in the back
Good luck finding a pic with the lenses off. It looks like it's plastic seam welded together. You'll need to cut it open. you can at sometimes find a few decents pics of the assembled unit on ebay that at least lets you see the backside.
I need to call around the bone yards and find a really cheap 96~97 center reflector for myself to work on as well. I'm not about to hack up my original.
Raoul Duke
I already tried it.
I used my Dremel to cut along the plastic weld. It took a very, very long time to get it all. Even though I was using good cutting discs, there was still some material I wasn't able to cut with the Dremel. For this reason, I had to carefully pry the panels apart using gentle force. I ended up cracking both sides and ruining the entire thing. The plastic is VERY brittle.
Have fun with that...
Resident Line Creator
Yea, mine ended up looking like this.
Wow that looks great..... which lights are those again?
I used the rear lights off a 91-93 like cougar_guy said. I found a set of broken taillights from a Thunderbird in the yard, and took only the LED strips out of them. I cut out a small section in the lights and put the LED's in place and siliconed it back up.
1 - 10 of 10 Posts
