I replaced my rear wheel bearing and the hub was machined down from the bad bearing. From what I've found there is 0 aftermarket and most likely will have to go to a scrap yard to find another. And at the scrap yard I'm sure youll have to buy the whole knuckle assembly unless you can press it out at the yard which I don't have the tools to do it there. I have a new brakes and dont want to resurface them on the car or have premature rotor warping
I have seen other messages of swapping the hub and knuckle assembly to a mustang but I want to keep it original. Will a T-bird rear hub fit a cougar? All I know to look for is a t bird rear fub from the scrap yards unless there is another market. Thank you in advanced.
