On The 1997 Mark Viiii I Have The 1450 Code That Wont Go Away After Clearing
From My Research Looks To Be The Purge Solenoid Would Anyone Agree? Or Are There Other Things To Look At? I Have No Cel Just The One Code P1450 That Wont Erase. Also Where Exactly Is This Part Located I Gather Passengers Wheel Well ? Thanks
Just Got Car Yesterday All New To Me As It Aint No Supercoupe!!!!
Probably Let The Wife Drive It , I Still Prefer My 95 Supercoupe For Some Reason..
Well, after I did a search here's what I came up with:
Possible causes:
EVAP canister purge outlet tube (EVAP canister purge valve to EVAP canister) blockages or kinks.
EVAP canister tube (fuel tank to EVAP canister) blockages or kinks.
Fuel vapor elbow on EVAP canister contaminated.
Restricted EVAP canister.
Canister vent (CV) solenoid stuck closed (partially or fully).
Plugged or contaminated CV solenoid filter.
EVAP canister purge valve stuck open.
Fuel filler cap stuck closed (no vacuum relief).
VREF circuit open in fuel tank pressure (FTP) sensor.
Damaged FTP sensor.
The purge canister seemed to be the culprit in most cases, but not all. It is located on the passenger side wheel well.
Go for it!
